Esim manager
champa1
In order to use Esim I need to have Esim manager option on my galaxy Samsung s9 phone but I don't find it under settings >connection . Could you please help?
Many thanks
Champa
Priority
Regardless of SIM Manager, you must have a phone from 2020 or newer with a Secondary IMEI2 Number in settings. The Samsung S9 unfortunately only has IMEI1 therefore only supporting the use of only Physical SIM Cards.
Provided you can get you hands on a newer Samsung Phone, you'll have SIM Manager built right into settings under 'Connections'.
@champa1
You need the Samsung A34 or newer in the A line or S20 or newer in the S line to have eSIM support.
@champa1
Galaxy S9 does not have eSIM, and it is a single sim phone, so you don't have SIM manager
You will need to stay with phsyical sim
