Error while changing my plan
Radwa
A .NET server issue
Edit: image removed for ordinal info protection
Issue fixed anyways
Edit 2: image re added
Post didn't make sense without it
Radwa
@Shereef yes it is working now thanks
srlawren
Curious that PM would not configure IIS to not serve up this type of detailed error page externally.  Really, PM, really???
giphy
Shereef
It's working fine now
I had the same issue
matbasm
@Radwa, since there is some private info in the image (email), you might want to remove the image, and just leave behind a description of the problem with the error message, or remove altogether.
will13am
@Radwa, this error happens from time to time.  Try clearing your browser cache or using incognito mode and giving it another try.
