05-01-2024
11:59 PM
05-02-2024
02:35 AM
computergeek541
I recently switched to public Mobile and I can make calls and have data but I cannot send or receive SMS messages. Because of this I can't sign in. I even tried to switch carriers back but I can't do that either because I can't receive the confirmation text. I've tried deleting my apns then restarting, I've tried creating apns manually and I'm not getting anywhere. Hoping someone here will have some advice.Thanks 🙂
My Account
Service
05-02-2024 12:13 AM
Thanks for the information @Dunkman . When I try to log in it doesn't say "didn't receive code?" It says "resend code?" Continuously and doesn't give an email option.
05-02-2024 12:08 AM
You can usually get the code send via email instead. Click on did not receive code and it should offer email next.
You will need to contact customer service agent to fix your texting issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
05-02-2024 12:07 AM
Thanks for the quick reply and great information!
05-02-2024 12:02 AM
don't switch provide, it is fixable and can be all sorted out tomorrow
PM is having problem provisioning text capability for new activations. And if you are an iPhone user, iMessage activation by phone number will also be impacted without a working SMS.
PM is working on a fix but for now, they can only resolve the issue on a case by case basis. Please open ticket with PM support by messaging CS Agent here:
