Enable subscription- meaning
treefrog
I've been suspended for awhile and need to reactivate in the next couple of days. However the last line in the pic below is a little confusing? Does that simply mean that auto pay is enabled or does it mean it will reactivate my account once I update my credit card details?
maximum_gato
@treefrog
With every new and improved self serve account overhaul comes confusing new wording for simple terms.
Enable subscription=Enable autopay.
Public Mobile is Grrrreat!🦁🐈‍⬛🤪
@treefrog  It means you will be auto subscribed (auto pay)
you can turn this off and on in my account also
Turn  auto pay  OFF/ON  3 easy clicks
Or if you know the 4 digit PIN number
*611
dust2dust
It used to be called autopay. Upon entering a card and making a payment then it will automatically turn on autopay (subscription).
