Enable auto-pay September 2019
possiblepmuser
What is the sequence of links to follow to enable, disable and verify auto-pay status?
Jb456
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Triguy
GR
@possiblepmuser  login to your self serve account and click on the payment Tab and you'll see manage autopay,  manage your credit card and make a one time payment
