09-29-2023 11:28 AM
I activated phone as per instructions. I received an error- that said contact customer service- 2 days ago!!
so I paid for ESim that doesn’t work - now what??
09-29-2023 01:29 PM
Have you tried to take out the physical sim card and reboot your phone?
09-29-2023 11:30 AM - edited 09-29-2023 11:30 AM
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone , disable them (eSIM/Physica sim) using the SIM Manager on the phone or remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled
(On iPhone, At Settings->Cellular , make sure the PM eSIM is set as Primary and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
09-29-2023 11:29 AM
what kinda phone you using ?
Make sure you're using the PM app to activate the new account...not laptop.
