08-28-2023
09:53 AM
09-02-2023
12:07 PM
Dunkman
Hello all,
I was porting from Telus esim to PM esim. When the PM esim was being installed, I received a text from Telus asking if I wanted to make the change. However when I reply Yes, the message failed to send out (seems the connection was already broken). Now I did receive welcome email (the email says my number was transferred) as well as text from PM, but the esim is showing sos only.
What do I do now?
Joining Public
Phones
08-28-2023 02:07 PM
if you check your Sim Manager, is the PM Sim card showing there? Make sure that is enabled. Also, disable the Telus physical sim. (If the phone ask you to reboot, follow it and reboot the phone)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
08-28-2023 01:52 PM
Hi @softech @hairbag1 @hTideGnow, I know I should have kept it. Luckily I had a spare physical sim to use. The Telus port out is done (called in port team to re-initiate the porting) but my PM eSim is still SOS only. I dont think I ever received a temporary number to use.
Do you guys know what should I do now?
08-28-2023 10:30 AM
HI @yrl79
you should keep your Telus eSIM
Now, you need to call Telus support and tell them what happened, they should be able to just move the number to your PM new account
08-28-2023 10:12 AM
08-28-2023 10:00 AM
Hey, well I deleted the Telus esimwhen I was trying to fix it on my own… because I remember it couldn’t be turned on (it was showing controlled by PM). Can I find another phone number to call Telus to finish the port? Assuming it didn’t finish due to the port msg failed to send.
08-28-2023 09:56 AM
check your messages box as I've sent you a number to call for assistance porting your number.
08-28-2023 09:55 AM - edited 08-28-2023 09:57 AM
@yrl79 since you are doing eSIM to eSIM on the same phone, it is a bit tricker
you will need to disable your PM esim from the SIM Manager first (disable, NOT delete), enable the Telus eSIM and you should be able to reply the Telus text.
Once replied, you can reverse it back, disable the Telus eSIM and enable back the PM eSIM.
Reboot every 30 mins and you should see inocming calls coming to the PM eSIM
Add: Check https://www.publicmobile.ca/en/qc/get-help/articles/transfer-your-number
Step 2: "Ensure your old service provider's eSIM is turned 'On" , again this is to allow you to reply Telus text
