05-26-2022
01:08 AM
05-26-2022
01:11 AM
computergeek541
05-26-2022 01:22 AM
Did you buy this used? You jay also want to confirm everything is kosher with the phone on devicecheck.ca
05-26-2022 01:16 AM
You should also be able to find it somewhere down in the settings. This would be different between iOS or Android. But generally in About.
05-26-2022 01:11 AM - edited 05-26-2022 01:12 AM
@Twocookies you can do that to get your IMEI #
Please note you will have to go back to the provider you got the phone from to get the carrier unlock code. If you get the phone from another provider, PM would not be able to assist on that.
@Twocookies wrote:I would like to get EIMI number to unlock the phone.
Using your phone, enter *#06# on your dialpad to get the device's IMEI. It'll be whichever carrier that the phone is locked to who you will need to contact.
