E-sim not activating
jul_enn
My e-sim won't activate and I've now been without a phone for 5 days. Does anyone know how long it takes to resolve? I've reached out to a customer support agent twice but no response.
9 REPLIES 9
jul_enn
I have done all that. I don't care about any promotions. I care about having a phone that I can use, and a number that people can actually phone me on.
Frank52
Sorry to hear about the long wait times to get a response back from Customer Service. The wait times for a response are unprecedented since this 50% promotion is almost too good to be true. Hundreds of new clients clients are in the same boat as you and submitted tickets at the same moment. Hang in there. Most people who got their response from Customer Service mentioned that their issue got resolved.
While you wait for their response, this could be a good article to review to make sure you followed all the necessary steps:
https://publicmobile.ca/en/get-help/articles/transfer-your-number
jul_enn
How long should I expect to wait? I would have thought that a waiting a week for a phone service to be activated would be beyond abnormally long. If it doesn't get sorted today I'll have to go with another provider and instigate a chargeback with my credit card company.
jul_enn
Update: tried all your suggestions and still not working. CS ticket submitted 48 hours ago and just silence.
No phone, no service - just terrible.
jul_enn
Done all that and still nothing.
Submitted a ticket on Friday. Zero reply.
So I'm stuck without a usable phone. Terrible service.
jul_enn
I can't log into the app because it wants to text a code to my phone number. And since I don't have a sim installed I cannot receive texts. I will look at your other suggestions and make sure I've done all of those.
Thank you.
hi @jul_enn
support is really slow in answering today. So, let's try to check something ourselves first and only message support agent if all are checked and still cannot make it work
can you confirm if the esim already installed?  It could be installed by the app and you don't need  the QR code to install.
fisrt, make sure your old physical sim card is removed , or if it the old carrier sim is esim, disable it from Sim Manager on Android or Settings->Cellular on iPhone
On the same Sim card Manager, or Settings->Cellular screen, check if Public Mobile esim is there. If it is , make sure it is set as Primary and enabled (or Turn on this line is enabled), then Reset Network settings
if that does not help, ask support agent to check,  submit  ticket by direct message:
slusagm
@jul_enn
is the eSIM showing on the phone? Check Sim Manager or Settings > Cellular
make sure other sim are disabled, only PM eSIM is active and Set as Primary
Reboot and Reset network settings
if that does not work, ask PM to help.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
@jul_enn  Support times are super slow and abnormaly long . But since you
submitting ticket keep an eye on your community inbox for their reply , or you can use this link to the community in box
https://productioncommunity.publicmobile.ca
