11-08-2022 04:18 PM - last edited on 11-08-2022 06:28 PM by computergeek541
When i make calls out it will drop call right away. But ppl can call me with no issue and i can recive the calls. I did phone reset but still not working
11-08-2022 06:44 PM
It somehow fixed itself few mins after i made this ticket. But thank you for your reply. I do apreciate it
11-08-2022 06:43 PM
It somehow fixed itself few mins after i posted this ticket. I had gotten home from an area 2 hours away so not sure if that had anything to do with it
11-08-2022 04:35 PM
have the same issue. Phone restart didn't help
11-08-2022 04:32 PM
Hi @theriaultmitch if you can receive calls but not able to make outbound calls, I am not sure charging to 3G only helps. You can try, no harm
Try reboot the phone and reseat the sim
Try to make calls in different areas and it should work when you are testing in different locations
what kind of phone do you have??
11-08-2022 04:23 PM
@theriaultmitch , do you notice any issues with signal strength? Have you done any software updates recently. It is strange that outgoing calls don't work but incoming does.
11-08-2022 04:22 PM - edited 11-08-2022 04:27 PM
Try setting your phone to 3g only network and try again.
If you're on the $15 plan with only 100 out going calls, then maybe your out of minutes. Login to your account and check.
