Dropped calls
04-26-2024
01:50 PM
04-27-2024
01:52 AM
computergeek541
I am finding that I am in the middle of a phone call and it suddenly disconnects. This has happened for several days now at different times. How do ifix this issue>
Service
04-27-2024 11:09 AM
More customer complains about voice quality and dropped calls. I forwarded this issue to PM staff, but will need to wait to hear their response.
From a different forum (reddit, RFD), one customer had the following fix:
For iPhone:
settings>>>cellular>>>Primary>>>network selection>>> turn off automatic network selection and reboot
If possible 5G network roll out issue, maybe try to force your phone to stay on LTE/4G instead of auto.
04-26-2024 02:31 PM
Actually I am getting the same issue, and I switched to another phone, issue persists. So I guess its the problem with the provider.
04-26-2024 02:00 PM
What model phone do you have? Is it VoLTE compatible?
https://www.publicmobile.ca/en/ab/get-help/articles/volte
Anything else different? Maybe location of the calls.
Maybe try a reboot of your phone. Network reset of phone (note: this will erase any saved Wifi passwords)
You could also try the SIM card in another working phone. That will help determine whether hardware issue versus PM service problem.
04-26-2024 02:00 PM
some had the same issue too, usually a reboot would work
but if reboot does not help, please ask agent to refresh your account
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
