04-12-2023 01:20 PM
Hi,
I lost my SIM card, while travelling. I came home to Ottawa and bought a new public mobile SIM card. To activate it I go to Profile->my account info->edit account info->new sim… And then SAVE does not work!
Please help !
04-12-2023 02:22 PM
Self solution removed
04-12-2023 02:12 PM
good to hear. Rather than assign the SOLUTION to yourself, edit your reply and re-assign Solution to whomever guided you to the answer first / best.
Use that little down arrow on top right side of the dialogue box to Edit Reply / Solution .
04-12-2023 01:39 PM
Worked from laptop. I didn’t do ‘incognito’
Thanks
04-12-2023 01:30 PM
HI @areguina
if you were using a mobile phone to make change of the sim card, please use a desktop or laptop. there is problem with the site if you use mobile phone
04-12-2023 01:24 PM
04-12-2023 01:23 PM
@areguina Are you using a desktop browser? You can try to clear your browser cache then use incognito/in private browsing mode to see if that will help. If those don't work, you can contact the CS Agent to help you update the SIM.
You can contact an agent using the chatbot. Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
