04-12-2023 02:41 PM
just activated the account and entered a wrong email
would like to change the email
04-12-2023 02:44 PM
Hi @irene94
welcome to PM,
Only CS agent and help with email change on My Account
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
