12-21-2024
09:41 PM
12-21-2024
09:47 PM
computergeek541
Hello
I am Trying to change my subscription. the plan is available for existing customer but can't seem to see it in the options when trying to change when I log in.
I confirm the lower tier plans are visible to existing customers when you are on a lower tier plan (Like $19 plan) but not visible to me. am on higher ($34 plan) !!! Confusing !
the Plan am using is 5G $34 / 50GB the plan am looking to change to this: 4G /$25 10GB .
Much appreciated .
Joe
3 weeks ago
Hi Joe,
I share your frustration by not being able to downsize. I wish I could change my subscription to suit my needs instead of paying for more than I need.
Thanks,
Grant
12-21-2024 10:11 PM
I Will Port Out ! Can't afford this Right Now
Thanks Again Mate !
12-21-2024 10:07 PM
@Joe_JIH2024 wrote:it's not just now. I tried to change couple months back same options as mentioned. Customers should have the right to change to lower tiers plans (not the new activation ones) when their circumstances change. Showing Mostly upgrading options and one lower plan is limiting and not letting you downgrade when you need it; that's on PM. Thanks . Merry Christmas
Agreed. Up until earlier this year, we could bounce in and outta plans at will...BUT...that changed and now we have very limited options if we wanna downgrade plans. One option is to get a new sim and start a new account but you'd need a different email address and get a new cell number. Not great options, I know.
12-21-2024 10:03 PM
12-21-2024 09:51 PM
you can downsize to it if it's available to you in your account. You can only change to plans you see in your account.
12-21-2024 09:48 PM
Hello
I still see the lower tier 4G $30 /20GB plan as an option . that's downsizing
12-21-2024 09:43 PM
that likely isn't available to you today as you have a plan of higher cost. PM won't let us downsize plans now.
