Does US roaming adds on work in Hawaii?
jgaoshmu
I am planning to travel for a week in Hawaii and I wonder if US roaming adds on works there? (Including data/voice/text).
Thanks!
To add to Oahu, also up the east coast.
Adding - and all 2G talk ie. Pre-volte
jgaoshmu
Thank you everyone for the great answers!
@jgaoshmu   yes, it will work in most area lik Honolulu,  Maui, Kannapalli, Kihei, Lahina, Paia, Wailea
this is the recent experience according to @slothie
 https://productioncommunity.publicmobile.ca/t5/The-Lounge/Recent-Public-Mobile-roaming-experience-in...
Dunkman
@jgaoshmu
Did you get a text from Public mobile that your service has been switched to VoLTE?
If you have VoLTE service and VoLTE enabled phone, you will have much better roaming experience.  3G network has been decomissioned in the US and previously, PM roaming was dependent on T mobile 2G network which has spotty coverage.
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
https://www.publicmobile.ca/en/on/get-help/articles/volte
jgaoshmu
Thank you for the quick answer!
hairbag1
@jgaoshmu,
for the most part...yes. Make sure to set T-Mobile as preferred network while there.
