06-30-2024
12:54 PM
06-30-2024
02:03 PM
computergeek541
I selected the incorrect data add on. Instead of canada, i misclicked data US roaming
06-30-2024 01:24 PM
Open a ticked and ask agent to assist you.
06-30-2024 12:56 PM
@Zmoke333, for this type of change you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
06-30-2024 12:56 PM
@Zmoke333 PM can help to switch if same price or put the credit back to the account and you can rebuy
just open ticket with PM by using the orange Chatbot icon on the lower right. Type the question Submit ticket and choose Contact us to open the window to submit ticket
