USA data usage
Richard6699
I just got the public mobile 100gb Canada USA Mexico plan, I went to the states today and I could not use data unless I turned on data roaming, does this mean I need to pay for the service, I shouldn’t have to turn on data roaming unless it’s not connecting to a partner service provider correct? Which service provider does public mobile use in the USA?
@Richard6699
@Richard6699 wrote:
So I should leave data roaming on and not worry about using data off AT&T or t mobile or Verizon, it is free from any service provider as long as I’m under my limit for the month
I've had my PM account since 2017 and I just leave data Roaming on all the time. You'll never get billed later for "overages". As a prepaid service, you only get the set amount of data included in your particular plan...once you reach that threshold, your data will just stop until next regular plan renewal.
Richard6699
hi @Richard6699
no worries, this is the right way to use data in US
it won't cost you extra.  It is just a device settings to allow your phone to use your non-regular network.
PM partners with AT&T, Verizon and T-Mobile.  Your network will automatically connects to one of the 3 US networks after you turn on roaming
