Canada US Mexico Plan
Purita
What can I/cannot do when I am in US or Mexico?
Can I use data so I do not have to set my iPhone on airplane mode? Can I send & receive text  to/from Canada, US or Mexico?
Can I call/receive anyone in Canada, US or Mexico?
any special instructions on settings / roaming, etc.
Purita
Thank you so much for your response. I am a new subscriber.  So basically, I can turn the airplane mode off on my iPhone, make sure roaming is turned on and the two-factor verification text should work as the text will go through on my iPhone.
Sansan
The Canada, Mexico,  US plan will work in all 3 countries just like if you are home yesterday.
Calls, data and sms.
Yes you would enable roaming and connect to either AT&T or Verizon or T-Mobile,  whichever connects.
CSA_PM
Customer Support Agent
Hi there!
With Public Mobile’s Canada–U.S.–Mexico plans, you can use your iPhone for data, calls, and texts across all three countries without extra roaming charges. Just enable roaming in your settings. Calls and texts to/from Canada, the U.S., and Mexico are included, and data works normally.
