PUK code?
TOS297
My phone asked for SIM PUK, please give me one.  I tried to open ticket but it sent me 2FA to sms and email, I have access to neither
please help and thanks
TOS297
thanks.  I messaged  them
slusagm
Ask PM to give you the PUK code.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
slusagm
You will need to ask PM to help
message them https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
slusagm
@TOS297
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/xYpc_I
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier help unlocking it.
           (Sorry, for this particular issue, PM support would not be able to help)
slusagm
PM can provide you the code
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
