06-07-2023 02:25 PM
4 weeks ago
I am on the same plan and have my incoming calls constantly disconnected at around 9min. Are you also having this issue?
06-08-2023 07:23 AM
Was in touch with PM and agent confirmed because my S20 was not on list, it's a no go.
06-08-2023 03:32 AM - edited 06-08-2023 03:33 AM
@BKNS27 wrote:Amended
I do see that you've edited your post, but that wasn't the part that I was trying to point out. You've stated that a 4G plan is needed to use VoLTE which isn't ture. A 4G plan isn't required to use VoLTE.
06-07-2023 11:11 PM
@frankysplace yes, VoLTE is for all, regardless of plan, just need PM to enable the profile and your device is on the list
So, what phone do you have?
06-07-2023 11:07 PM
I have the 15 dollar plan and 250mb of 3G data and VoLTE is activated on my phone.
06-07-2023 07:41 PM
Amended
06-07-2023 05:57 PM - edited 06-07-2023 08:56 PM
@BKNS27 wrote:Yes but you also need to know if your phone is also PM 4G/LTE compatible.
Note that 3G is on 4G but throttled down speed.
Please be aware that the information that you have provided isn't correct. The previous responses have the correct answer that a 4G plan isn't needed to use VoLTE.
06-07-2023 04:32 PM
@STEON1 yes, I have an S21+ and didn't make it onto the list either. And unfortunately, iPhones always have an advantage on these things 😞
06-07-2023 04:30 PM
Hoping they do update, iphone8 which is on list came out in 2017 and the S20, 2020
06-07-2023 03:59 PM
@STEON1 wrote:Have a S20 plus . Not on Public Mobile list, but passes on Telus IEMI checker
@STEON1 , it is best to make a call and check whether the phone remains connected to the LTE network for voice. At this point, I would not rely on anything other than this check. I have had a phone not on the list that worked for about a month and now is no longer getting VoLTE. Something angried the system and the IMEI got removed from the whitelist.
06-07-2023 03:40 PM
@esjliv yes, you got it!!
honest, I doubt they will update it a lot
and with this morning's post by sheytoon saying 3G is not going anywhere anytime soon, I doubt PM has much incentive to bring older phones onto this VoLTE list. I think new phones from this point will be good, doubt the old one that didn't make the list will be there
06-07-2023 03:22 PM
@STEON1 @softech - are you looking at this list at the bottom of this help article: https://www.publicmobile.ca/en/on/get-help/articles/volte ?
I never noticed this before. Wonder if this list is going to be updated regularly by Public Mobile?
06-07-2023 02:34 PM
@STEON1 Sorry S20 Plus is not on PM's VoLTE compatible list. The list PM has is different from Telus'
06-07-2023 02:33 PM
06-07-2023 02:27 PM
@STEON1 No
06-07-2023 02:26 PM - edited 06-07-2023 07:40 PM
Yes but you also need to know if your phone is also PM 4G/LTE.
06-07-2023 02:26 PM
