3 hours ago
2 hours ago
@rooster2 No you don't need an add-on with a Canada-US plan, it should work for calling US to Canada and vice versa and within each country. You might get a reminder text about roaming add ons when you cross the border but you can ignore it. Do you have a PM VoLTE approved phone? If not voice calls could be an issue (in the US only).
3 hours ago
HI @rooster2
if you have Canada US Plan, you don't need any extra addon
with the plan, you can call and text from US to Canada as well as call and text from US to US, of course you can use data while in US
just make sure you turn on Roaming data, and try to connect to T-Mobile or AT&T or Verizon. Sometimes if it does not connect well, choose manual connection and try all 3 networks
