12-08-2023 08:44 AM - last edited on 12-08-2023 08:03 PM by computergeek541
12-08-2023 09:20 AM
HI @DaveeBoy
there is no need for the new sim card. The same one can be used for 5G plans. I just helped my friend upgraded from 3G to 5G, he has a very old sim card and still work without problem. So, enjoy the new plan with SPEED 🙂
12-08-2023 08:47 AM - edited 12-08-2023 08:50 AM
@DaveeBoy No you don’t just take sim card out of old phone and put it into the new phone and that’s it . Only thing if you notice the SIM card seems to big for the new phone , you can pop off the outer edge to make the sim right size for the new phone
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
