Do I lose my per-month discounts if I switch to the promoted plan?
Isthatok
I'm currently on a $40, 5 GB at 3G plan but I really only pay $33/month because of the loyalty pays, pre-authorized payments, and refer-a-friend rewards. I understand this is an old rewards system different from Public Points.
I'm considering to switch to the $40 Unlimited Canada-wide minutes + 15GB data at 4G plan.
If I switch do these old rewards still get applied (i.e. will I still be paying $33/month?)
Just want to make sure. Thanks!
7 REPLIES 7
I believe you can do it yourself. Just click on little arrow on top of your message and remove solution.
Isthatok
Can a mod change the accepted solution to @Meow 's solution? The one I selected is actually confusing due to the title of the thread.
Isthatok
Beautiful thanks everyone!
brettster99
Yes
Meow
Your rewards are tied up with your account and not plan so you can switch every 30 days if you want.
You will not lose any rewards changing plans.
Gunner123
@Isthatok hi yes you get to keep them,just don't switch to the new rewards program
Tsawwassen
You will not lose your discounts.
