11-09-2019 01:52 PM - edited 01-05-2022 07:55 AM
Plans say international texts but what about calls? If I go to the United states and someone from Canada calls or texts me when I am there, do I get charged international fees? Currently I am with Koodo and I can call or text a US number without international charges provided that I am still in Canada. I can also go into the US and call or text a Canadian number or a Candian Number can call or text me without international charges because my number is Candian based. I'm heading to the US for vacation in Dec and I am just trying to figure out if I am better off waiting until after I come home to change providers or not. We don't really need to use the phone to make local calls while we are there but we would like it so that people back home have a way of contacting us.
11-10-2019 11:40 AM - edited 11-10-2019 11:40 AM
I have received text messages on my PM phone with no add-ons (and not the now discontinued US plan) while travelling in the USA. Can't send a text though.
AE_Collector
11-10-2019 11:38 AM
You are correct: you would be able to receive incoming texts in the USA without roaming package.
Not sure about voicemail notifications. Probably not. Somebody else can verify.....
11-10-2019 11:25 AM
I believe I read that even without a US roaming addon, you can still at least receive texts whilst in the USA? If so, would voicemail notifications come through as well?
11-09-2019 02:57 PM
@geopublic wrote:@courtneyf Your better off to switch when you get back IMHO. Your public mobile will not work in the US for outgoing calls and texts without purchasing a 10 day US roaming addon package. Furthermore International texts is only valid when you are in Canada.
Save for one of those unofficial Public Mobile gltiches that might sometimes allow it, incoming calls while you're in the U.S. aren't supposed to work either without a roaming add-on (or the $60 plan that included U.S. roaming).
11-09-2019 02:55 PM
@kpurest wrote:I am using 40$ plan, when I was in state, I can't send message or calling to canada, even usa.
You need to purchase roaming additional cost 10$ if you want to.
You weren't supposed to be able to use your Public Mobile service while in the U.S. without a roaming add-on. The $10 roaming add-on is for data only. It doesn't enabled voice or text messaging usage while roaming in the U.S.
11-09-2019 02:21 PM
11-09-2019 02:04 PM
@GinYVR wrote:
@courtneyfAs long as you have US add ons or the grandfathered US/Canada plan, you won't be charged anything if anyone calls your Canadian number while you are in the US.
Kinda hard to get a grandfathered $60 US/Canada plan when your are currently a Koodo customer.
11-09-2019 01:59 PM
11-09-2019 01:58 PM - edited 11-10-2019 04:27 PM
@courtneyf You're better off to switch when you get back IMHO. Your public mobile will not work in the US for outgoing calls and texts without purchasing a 10 day US roaming addon package. Furthermore International texts is only valid when you are in Canada.
