12-28-2022 05:47 PM
Hello I never got my Holiday reward and can't seem to submit a ticket through SIMon. How do I get my rewards? (Bonus points if it doesn't include a phone call)
Thanks!
Add-Ons
12-28-2022 05:54 PM
DON'T POST ANSWERS IN PUBLIC FORUM!!!
Osvaldo, you should communicate with customer over personal mail not through public forum. Not all customers understand this is a PUBLIC forum and not dedicated PM support provided by PM staff.
12-28-2022 05:52 PM
HI @Keeley did you try send YES2 to 4911?
or you can open ticket with CS agent here
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-28-2022 05:52 PM - edited 12-28-2022 05:54 PM
12-28-2022 05:50 PM
Contact agent to add bonuses manually.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
