Anniversary Points not Applying
EnriqueL
Recently forced into points program. I was previously getting $5 back per month because I’ve used public mobile for over 5 years. Now it seems they changed it to 10 points for every 12 months. This is less than $1 back per month and doesn’t reward staying longer than a year.
Will I now only receive this 10 points once per year? Or will I receive points every month to replace the $5 incentive I was previously receiving?
7 REPLIES 7
turtleTurtle
It is replaced with 5% back in points on what you pay, so the amount you get will depend on what plan you have.
Jess31
In addition to the 10 points once a year, you get 5% back in points on what you pay each month. Depending on what plan you are on, you will likely not get $5 back each month, but you will get something.
While unfortunate, this is the direction they have decided to go.
@EnriqueL if you have a $25-1GB plan, then "proce decrease" for you now. PM currently has a $19-1GB plan for existing customers. It is the same $25 plan, but better, it comes wirh 4G data
So, if you are interested in the $19 plan, go My Account, click Change Subscription and select the $19 plan.  Use Change on Renewal to schedule a plan change
EnriqueL
Plan prices have only increased. I’ve paid $25 for over 6 years and never saw a price decrease.
@EnriqueL how much is your plan??  PM's plan price has came down a lot, did you check if any of the current plan suit your nerds and cheaper??
and true, you will earn less because of the loss of loyalty, but you will earn a 5% back in points, that will help a bit
EnriqueL
So confirming that the points plan has made my bill $50.04 + tax more expensive per year?
@EnriqueL you will now get 10 points once a year on your anniversary date with PM.  To confirm the date, login PM app and go to the Account page and it will show there
