07-28-2023 09:09 PM
How come I didn't receive my e-sim in my activation email, when I chose to use an e-sim through the ordering process? I contacted customer service but they won't send out a QR code? HELP
07-28-2023 10:04 PM
after picking the number, the app would try to install the eSIM for you
But first, what phone do you have? brand and model?
and check @Priority 's experience of eSIM activation here
https://productioncommunity.publicmobile.ca/t5/Get-Support/e-SIM-Activation/m-p/1020154#M711335
And if you have a compatible eSIM device, you should still able to push support to help with eSIM activation
07-28-2023 09:44 PM
Yes still stuck at that step because as soon as I choose to pick a new number, it loads and then fails to read esim because they didn’t send me out one on my activation email
07-28-2023 09:28 PM
so you didn't complete the activation step yet? you still stuck at the step about picking phone number or transfer number ?
07-28-2023 09:24 PM
I have sent another private message in the customer support. the one agent I have been dealing with has NOT been helpful at all! They told me to purchase a physical SIM but the app is stuck on the activiation step of either porting a number or choosing a new number. So frustrating
07-28-2023 09:11 PM
The app didn't try to install the eSIM for you?
for the QR code, check if the PM email fell into the Spam folder
if not, no worry, message support and they can re-send you the QR code
