12-28-2022 01:02 PM
Hi, both my wife and I are existing public mobile customers but neither of us receive text for the holiday reward. Is there another way to claim it?
12-28-2022 01:18 PM
Thank you for the replies. I tried texting YES2 to 4911 but it didn't work, so I just submitted a support ticket.
12-28-2022 01:07 PM
HI @hthan
it is not too late.
Please open ticket with PM CS agent today and they will add it back for you quickly. My friend did it and got it back in couple hours
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-28-2022 01:07 PM
@hthan @Also you wanna try to get this resolved before dec 31/2022 as offer ends on that date
12-28-2022 01:04 PM
Not to worry!
Contact agent to add your bonuses manually.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-28-2022 01:04 PM
@hthan @First try texting YES2 4911 . If that doesn’t work you need to open a ticket
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
