Delivery of SIM card
09-04-2024
05:37 PM
09-04-2024
06:37 PM
computergeek541
I had ordered a SIM card on the 10th of August, now 4th of September and I have heard nothing about delivery. Tried finding a a help page for this to get it re delivered, but nothing. Is there anything to fix this?
Joining Public
09-04-2024 08:53 PM
no need to repeat others hours later
09-04-2024 05:44 PM
@Fin1 Ask support for a update and to send out a new one instead that’s to long
09-04-2024 05:42 PM
@Fin1 it should have been received by now. Usually 10 business.
You can find a local Telus/ Koodo/mobile Klink shop and see if they sell it and purchase right away for $10.
Or oder from Amazon.
Once you have the SIM, you can use the chatbot to ask PM IF, they are able to credit you for the extra $10.
