Deleted old email and forgot password
Sao
Hi I no longer have access to the email I used to sign up as I deleted it. I also forgot my password so I can’t reset my password using my email. I need to log into self serve and there are no valid options with the chatbot.
@Sao
 you hae to Contact Customer Support Agent by  , Explain your issue
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
  • you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,>> you will say need change,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck...
@jib_tech wrote:
@JK8
How come I can't bravo anyone anymore it gives me a red warning?I can only give you one of these👍or maybe one of these💪lol!
you can try it on my post again  🙂
Yes, there is a limit to how many bravos in a minute or so.  Not sure if it is something new or it has been there but just no one notice.  But there was a post last week talking about this too.
@jib_tech wrote:
@JK8
There's limits on bravo giving. You gave too many quickly.
jib_tech
@JK8
jib_tech
@Sao
You have to contact the CSA's and give them a new email. They ask you some questions like your birth date and stuff then you can change it.
JK8
@Sao
Contact a CSA. Second option is easiest.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
