Deactivate
Gillb9
Where do I find the page to turn off auto pay?
8 REPLIES 8
dust2dust
@softech- We differ a little on this topic. To go to a different extreme, the author of a scientific paper that cites other scientific papers doesn't go around asking if they can cite/use someone elses work. The citation gives the credit. You did the work on those images. You should be given the credit. If someone makes an image that looks a lot like that but different then there's not much you can do.
I had a cursory look at using watermarks but I don't care enough. As long as the person that did the work gets the credit then it's fine. This person did not. So I pointed that out. But I venture to guess they don't care about all these niceties.
Thanks @dust2dust for pointing out.
NO.  @not-trust-anyon did not tell me ahead that she is going to use the image., nor any credit to the source. In fact, looking at @not-trust-anyon  image library, all the images there are  either exactly the same or very similar to mine.
I understand everything posted here belongs to Public Mobile/Telus.  But I woild assume even if  Community Manager @J_PM wants to use other's work   she would politely ask first.
This also remind me of another user name @0077 .  She has been doing the same thing, rudely used my images in her replies.  I don't think that was an act of appreciation but more an unfriendly act.  Afterall, how hard to make your own?  Why need to copy someone images or copy others text?
Here is one I found from my image library
https://selfserve.publicmobile.ca/en/account/payment/manage-card-summaryhttps://selfserve.publicmobile.ca/en/account/payment/manage-card-summary
@not-trust-anyon- If you're going to make use of someone else's work then it's properly respectful to give credit. I thought that looked like the handiwork of another member and indeed it is. Yes it's all publicly available to everyone but you didn't do the work. Work deserves credit.
dabr
@Gillb9   Here's the link to login into your self serve account if you still are unable to find it:  https://selfserve.publicmobile.ca/
@Gillb9 wrote:
Where do I find payment? I log in and it brings me to the forum.
As with the method of clicking on the account sign in options that dust2dust mentioned, going to the site that I mentioend of selfserve.publicmobile.ca takes you directly in your Self Serve account.  It doesn't take you into Community. You've accidently went ot wrong site.
Hover over Sign in upper right and it will pop down a couple options. Click on My account. Then the payment tab on the left.
Gillb9
Please log into your account at selfserve.publicmobile.ca and go to the payment section.  There is selection to turn pre-authorized payments on or off.
