Cancel subscription
CarlosYVR
Hi! I'm leaving Canada next month and need to cancel my subscription. Could you let me know how to do that, and whether I also need to cancel/deactivate my SIM card? Thanks!
2 REPLIES 2
@CarlosYVR
since you do not need the number anymore, all you need to do is to disable Autopay so Public Mobile won't charge you anymore
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
Or if you cannot login My Account to disable Autopay, you have to open a ticket with PM Customer Support and ask them to help to remove the credit card.  Please open ticket using Public Mobile Expert Messaging , Select Start a Chat to begin (You will need to use your current Community account to login to submit the ticket):
          https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/sms alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
** If you cannot receive 2FA code via SMS and hence unable to open ticket, please use another email to setup a different Community account and do not link a phone number to it.  Having this new community account without a linked phone number, the 2FA will be  sent to the email address only, you would then be able to create an Expert Messaging ticket.
hairbag1
@CarlosYVR
simple...just log in to your Public Mobile account and disable SUBSCRIDED. That will stop future payments and acct will eventually deactivate.
