02-15-2024 05:19 PM
@hTideGnow @will13am @CS_Agent
Hello
My daughter has lost her Public mobile phone and i cannot access My Account as the option is to send text or voice message to the phone as part of the 2 FA setup.
On logging in using username and password, i get the option to enter the code sent as text to the lost phone. On choosing resend code option, the follow up screen has only two options, Send text message OR Send voice message. I cannot access the lost phone to get the text or voice message.
Pls let me know how to to deactivate the 2 FA. I need to report the phone as lost /stolen.
Thanks
Noel
02-15-2024 05:24 PM
Try these workarounds, it could unlock the Send email option
If none of those workarounds helps, please open ticket with support by direct message here:
02-15-2024 05:23 PM
HI @Noel_M
first, I am just customer like you 🙂
for you case, best to submit a ticket with PM support. please submit a ticket with CS Agent here:
02-15-2024 05:22 PM
@Noel_M - Please Click, 'Send Email.' If this is your first time in your My Account, you won't have that option, you will need help of a CS_Agent. Also if you are on iOS, you can login to find my, and if on android, search up, 'Android Find My device.' Samsung also has a specific website for it too.
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. Please ensure that you pay attention for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
02-15-2024 05:21 PM - edited 02-15-2024 05:22 PM
@Noel_M CS Agents can help you in this case
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
02-15-2024 05:21 PM
Did you try tapping the "Didn't get the code?" option which should then present an option to get it by e-mail?
If that fails, contact support
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
