12-03-2022 11:32 AM
May I ask 2GB one-time data bonus and Reward 1GB Add-on (Free) is 3G speed or 4G speed?
Add-Ons
12-03-2022 11:16 PM
I like your name
12-03-2022 11:59 AM
That's why I suggested that you scoll around until you find it. You'll like it, because I have that plan! lol
12-03-2022 11:56 AM
Now I see, Thank you so much
12-03-2022 11:52 AM
But here show 40 for 5G, Not 15 G, How can i get 15 G?
12-03-2022 11:49 AM - edited 12-03-2022 11:50 AM
Log in to My account,Plan and Add-on page, click Change my plan , then choose the 4G tab. be aware there are two $40 plans there, pick the correct one. And use Change on renewal date to avoid lossimg moneyhttps://selfserve.publicmobile.ca/en/account/plan/change-plan
12-03-2022 11:49 AM
Okay, Thank you
12-03-2022 11:47 AM - edited 12-03-2022 11:50 AM
You can see it from in your account plans 4G. Just log into your account and click on Change my plan. Look under 4G plans and scroll around.
12-03-2022 11:46 AM
How can i get it?
12-03-2022 11:45 AM
@旋转的摩天轮 the $40 for 15gb is still on and is a good plan. consider going for it
12-03-2022 11:39 AM
Yes, it will. But if you do an immediate plan change you will not get any credit for your current plan. It is better to choose change plan on next renewal date.
12-03-2022 11:39 AM
@旋转的摩天轮 wrote:Okay, Thank you, Now my plan is 3G speed, If now i change my plan to 4G speed, it will be change 4G speed or not?
Best guess...it'll still be 4G.
12-03-2022 11:38 AM
It will switch to 4G
12-03-2022 11:38 AM
Okay, Thank you for reply
12-03-2022 11:37 AM
Speed will depend on your plan.
12-03-2022 11:37 AM
The speed will be whatever you have now in your current plan.
12-03-2022 11:36 AM
12-03-2022 11:33 AM
