09-07-2022 07:14 PM
My account says i have data left but my data is not working
07:18 PM
09-17-2022
03:54 PM
Luddite
[spurious comment deleted ...... Luddite]
09-07-2022 07:17 PM
@TylerMoogk - call 611 to check your data balance, to make sure it matches your My Account.
Ensure your data option is turned ON in the settings of your device.
If it does not match, open a tab in incognito mode then log into My Account. Also, try hitting that circle with an arrow button to refresh your data usage.
If you have data showing and still doesn't work, try:
Check for outages in your area:
https://www.telus.com/en/on/outages
09-07-2022 07:16 PM
With this new site, you likely still reading off the cached version, so the usage you got could be wrong
Try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome. You should then see the latest usage from the server
09-07-2022 07:16 PM
Log in to your account using incognito mode to see if you do have any data actually.
Let us know.
