Data
04-12-2022 04:41 PM
04-12-2022 09:18 PM
@YJW wrote:I have an LG G4 and yes data has worked before
HI @YJW How long was before? Was it still working yesterday?
If you have checked My Account and see you still have data left , maybe you should try to perform a network reset. Especially if you used this phone on other network before, LG might need a network reset or even factory reset to get the data working again
04-12-2022 08:55 PM
It is probably not the case but to double check. Is your Cellular Data setting is enabled?
04-12-2022 05:47 PM
If you DO HAVE data showing as remaining in your My Data & Add-On's section, then try:
- toggling airplane mode on/off
- resetting your device network settings
- rebooting your device
- removing SIM, then reinsert it
- you might also want to try manually switching the network to 3G only, then try your DATA
04-12-2022 05:29 PM
@YJW wrote:I cannot get data
You mean Internet is not working?
What your self-serving account says, how much data you have available?
04-12-2022 05:22 PM
My suggestion as a first step would be to review your Self Serve account to see how much data is remaining. if under Data and Add-ons, there are no data counters shown, this means that all data has already been used.
04-12-2022 05:01 PM
04-12-2022 04:46 PM
What make and model of phone? Are you new or has data worked here before?
