04-09-2026 10:03 AM
I have 5gb of data. Have only used .25. My Cellular Data is turned on. But when I try to google maps, send WhatsApp message, or anything else that requires data, it says my data is not turned on. I go to settings, data is turned on, I toggle it off and then on again. I even turn on the roaming but still am unable to use my data. What is wrong?
04-09-2026 10:26 AM
Which model phone are you using? If Android, you may need to adjust APN settings.
04-09-2026 10:15 AM
good question...try rebooting your cell. If that doesn't help, try a network reset. Let us know if that helps.
