Data top up
05-09-2023 06:00 PM
05-09-2023 08:59 PM
Ok I sent a message using your link
05-09-2023 08:58 PM
I just tried it didn't work, thanks tho
05-09-2023 08:55 PM
@TristanB did you open via Chatbot or direct message? there is a problem with chatbot today, please message them instead if you used chatbot
05-09-2023 08:53 PM
I did send in a ticket I still haven't got a response back
05-09-2023 06:02 PM
When you log into self-serve, and tap the little refresher icons on the page, does the data add-on display under your Data and Add-On's section?
Try rebooting your device and toggling airplane mode on/off.
05-09-2023 06:02 PM
@TristanB reboot your phone once more
Also, check if you have data limit enabled, if so, please disable it and text
if it still does not work, you will have to open ticket with CS_Agent instead of just tagging them here
please open ticket by direct message (since chatbot ticketing is down)
