Data stop working
Blackcat0808
My data stop working from no  where. Need help. I have restarted my phone and took my sim card and back in, still do not work.
8 REPLIES 8
Blackcat0808
Connections reset solved the issue!
hi @Blackcat0808
also, make sure you don't have a data limit set on your phone.  If you do, disable the data limit
if you have a physical sim, test on another phone
last, submit a ticket with PM agent using the link in my above post
Blackcat0808
It shows I used 6gbs out out 60gbs
DarkKnight_1000
Hey @Blackcat0808
Could you try resetting your network settings
Also, try switching your network mode from 5G to LTE only and see if data starts working again.
Yummy
First check your PM account to confirm you do have data available.
hi @Blackcat0808
what phone do you have? you checked My Account and confirmed that you still have enough data?
or call *611 form it phone, it will tell you how much data left
and check any outage in your area
https://www.telus.com/en/bc/outages
last, ask PM agent to check and refresh your account if needed
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
