Data not woking
briannaL
switch to public during that flash sale. everything works except for my data. tried all the steps in the help section. need help.
2 REPLIES 2
Narendran
Try adding a new eSIM, it should fix the problem. Worked for me!
hi @briannaL make sure your old carrier sim is removed
then Reboot phone and click Reset Network Settings and test again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
