Data speed
Options
02-24-2024 12:52 PM
Since 2 weeks ago im getting bad speed even with 4 bar on LTE is there something I can do to fix that?
Labels:
Service
2 REPLIES 2
Options
02-24-2024 12:56 PM
@OlivierR If you try again later in a different areas you’re bound to get different results . So many variables network congestions the area are you near construction ATM . It will always give different results at different times .
Options
02-24-2024 12:55 PM
test out 3G...see if any improvement.
