Data
02-24-2024 12:26 PM
02-24-2024 12:58 PM
@AngelaSears wrote:I’ve been a customer of Public Mobile for over 10 years. I can call but not text or go on the internet. The internet bars when not in wifi area was not showing very strong, only 2 bars.
Thanks for the information.
You may want to try the following:
Reboot your phone.
Network reset of phone (note - this will erase any saved Wifi settings).
You could also try your PM SIM card in another working phone. This will help determine whether hardware issue versus PM service problem.
02-24-2024 12:49 PM
Thank you I have tried turning Airplane mode on and off and now phone. I will look into the rest though. Thanks for the suggestions and help.
02-24-2024 12:47 PM
Last thing I can suggest is to sign into your account to check the status.
If you have and it's show all good and nothing turned off I'm settings, then message cs agent below. Maybe account needs to be troubleshooting.
You can also turn on and off airplane mode. Restart phone to see if helps.
02-24-2024 12:46 PM
02-24-2024 12:42 PM
Everything is turned on, I pay in advance every 3 months.
02-24-2024 12:36 PM
Ok is your aaccout active? When was rhe last time you paid?
02-24-2024 12:33 PM
More details would be helpful. Community members are customers like yourself. We can offer troubleshooting advice, but don't have direct access to your account.
New customer versus old?
Active versus suspended account?
What about talk, text?
Did data work before?
02-24-2024 12:29 PM
What all can I check on my settings ? I have never had this problem ever before. I can’t even send a text!
02-24-2024 12:28 PM
Check that your data is turned on. Ensure you haven't used up all your data. Check the settings on your phone that something is not tuned off.
