10-16-2021 07:53 PM - edited 01-06-2022 03:33 AM
Getting 1Mb instead of 3. Also affecting my kid's phone in another city entirely. Any ideas?
Service
10-17-2021 07:24 PM
Another thing to check is how many signal bars you are getting. Even though LTE is faster, If you are getting 1-2 bars indoors inside a basement, it's better to disable LTE so it'll use lower better penetrating frequency signals. Also saves on batter since phone will not be fighting for proper signal. Myself I always disable LTE even if I get 3 sig bars, I get better speed and battery under 3G. Cheers!
10-17-2021 03:09 PM
no. I'm not open minded I don't want to know... 🤫 😖
10-17-2021 11:02 AM
@gpixel I have tested Koodo with PM.
Guess who won..
10-17-2021 09:23 AM
Disabled LTE and went from sub-1Mbps to 10Mbps. Interesting. Cheers
10-17-2021 06:35 AM
i would have to respectfully disagree with him. public clearly states this and this is something we can all test and observe. Ive seen many customers compare their Telus account and their public account reception.. and the answer is never the same. public loses... all the time
10-16-2021 10:43 PM
Not according to sheytoon.....thats an old wives tale!
10-16-2021 10:13 PM - edited 10-16-2021 10:14 PM
depending on tower saturation, you could be kicked off the nearest tower and reconnected to a tower further away. this could happen during high traffic hours.also weather can play a big factor and being indoors. there are many factors
it goes Telus, Bell, Koodo, Virgin, Public, Lucky for tower priorities
10-16-2021 09:39 PM
Try rebooting your phone and turning airplane mode on for a minute and off again.
10-16-2021 08:09 PM
Data speed can be slower depending on location and conditions at the time.
Maybe try to manually select 3G network, instead of LTE or auto. LTE speeds with Public mobile is capped to 3Mbps, while 3G network is not capped and many customers can get higher speeds. Will lose the LTE latency, but data speeds might be higher.
10-16-2021 07:56 PM
Too many kids playing games at the same time? 🙂
Could be just network overload... Saturday night, rainy weather, everybody at home...
