Data settings: The option to add a new APN setting is missing
peaceschool
Hi I’m using Figo orbit II phone, android 8.1 Oreo Go Edition operating system (OS), on the APN screen there is no option to add a new APN so I cannot continue with my data setting.
Lol good to know.. A little freedom mobile workaround, makes things a little complex but at least it's an option
Hi @peaceschool try a network reset.  it might get the correct APN without manually update the APN
Another way is to factory reset with the PM SIM on the phone, the APN might come down  that way automatically
darlicious
@peaceschool
Can you update your OS to Android 9? If not you have 2 choices:
  1. Borrow a freedom sim card which will allow you to add public mobile's APN.
  2. Contact customer support and ask them to text you a configuration file to update your carrier profile to public mobile's APN.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
Yummy
APN SETTING iPhone
Changing APN settings on an iPhone click HERE.
Changing APN settings on Android phones click HERE.
For android
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
