Finishing set up
AnnaLD
I thought my phone was e-card compatible but it's not I bought a sim and cannot finish set up
hi @AnnaLD
have you checked with PM support yet?  sometimes the error with compatibility of the esim is a false negative.  Check with support first
@AnnaLD
Just curious on what is the make and model of your phone?
@AnnaLD so, you have a sim card already? you will need to ask support to update the sim card number for you
Sansan
@AnnaLD  buy a physical card from Amazon or call a local Telus/Koodo /mobile Klink store and see if they have Public Mobile SIM card and buy for $10+. Once you have it, message PM agents to add the Physical SIM card number to your profile.
Or you can purchase from the App.
