05-28-2023 03:02 PM
Hoping someone from PM will reach out to correct this issue. My data usage did not reset to zero at the beginning of this billing cycle, and now I'm stuck with no data. Please get this issue resolved asap. Thanks.
05-28-2023 03:26 PM
HI @Lisa0211 Video is a killer.. LoL 🙂
Yes, as suggested above, $39 plan is the Best Bang for Your Buck at the moment if you need more data
05-28-2023 03:24 PM
It was a video streaming app that I used to watch some live church services...
05-28-2023 03:22 PM
@Lisa0211 still many days left in your current cycle.
best to ask for early renewal, help from PM support, or you can do a manual plan change to a plan with more data. $39 plan is a good one
05-28-2023 03:21 PM
HI @Lisa0211 so which app used most the data?
05-28-2023 03:20 PM
@Lisa0211 Then if you don’t already know there’s a 20GB plan for $39 you can change to for next renewal be $1 cheaper and give you 5GB more assuming your in the 15GB for $40 now
05-28-2023 03:18 PM
🙈you're right. I didn't realize I was using so much data. Figured out what my problem is. It's not a PM issue, its an issue of me not realizing how much data I'm burning through. Thanks.
05-28-2023 03:14 PM - edited 05-28-2023 03:15 PM
@Lisa0211 on your device, goto mobile data page, change the billing start date to may 22 and it will tell you how much data used and which app used how much. You can tell if you really used up the monthly data, likely yes
05-28-2023 03:13 PM
no, no data limits set on my phone
05-28-2023 03:12 PM
May 22. Samsung Galaxy S20
05-28-2023 03:12 PM
@Lisa0211 Do you have a data limit set on your phone
05-28-2023 03:11 PM
05-28-2023 03:09 PM
With this new site, you likely still reading off the cached version, so the usage you got was not up to date
An easy way is to click the Spinner on the bottom right of the section to force a refresh.
If you don't see an updated usage still, try to login My Account using Incognito mode (or InPrivate for Edge, Private for Safari) or try again with a completely different browser like Edge/Firefox/Chrome or try on another device. You should then see the latest info from the server.
05-28-2023 03:09 PM
already tried this, but it doesn't fix problem. Data is turned on in my phone, and status bar shows LTE, but I am locked out of using data. There's a message on my phone that says "sign in to public mobile", and when I do, a website from public mobile appears saying that my data plan is exhausted, and I need to buy more data. However, I know that my data usage was almost exhausted, and my billing cycle renewed on May 22, but the data counter did not reset to 0, but kept climbing to my 15GB limit, and now I'm locked out of any data usage on my phone
05-28-2023 03:07 PM
HI @Dunkman I was hoping the new site will correct the problem. I guess not 😞
05-28-2023 03:06 PM
The website has caching issues. Showing inaccurate, old information.
You may want to refresh the page. Might want to try to login with a different web browser, clear cache or incognito mode. That would show the most up to date data usage.
05-28-2023 03:06 PM
HI @Lisa0211 most reset issue was just because you are checking a old cached page locally.
Please login My Account again using Incognito/Private/Secret mode, you should see the correct counter then
if still not, open ticket with CS agent using message:
05-28-2023 03:03 PM - edited 05-28-2023 03:04 PM
@Lisa0211 Try this first
simply try refreshing the page when logged in
also ensure data is turned on , on your phone and that your account is active
add if you need support for anything else here’s the link
