Data priority
ahoyitsmatt
What is the priority in which data and data add-ons are used?
Lets say I have a 250 MB data plan per month, and I also purchase a 1 GB data add-on.
When I use data, does it go through my 250 MB of data first before subtracting from my 1 GB?
Or is the priority to eliminate the data add-on before hitting the monthly data-plan?
Thanks
1 REPLY 1
Triguy
Your plan data is used first then your add-on is used until it is depleted.
