Data plan
msashakil
Hi,
I use $40 plan, I was supposed get 5 gb of data, however,  I don't see any history that I have or I used any data grom that 5gb.
2 REPLIES 2
darlicious
@msashakil
You have experienced this before...when was your renewal? Tonight/today? Or only a couple of days ago? If your 5gb data counter did not reset and reappear ( if you used it all in the previous 30 day cycle) then it's possible a glitch did occur and you can contact customer support to have it properly reset. If you are mid cycle then add up your daily usage back to your renewal date and it is less than 5gb a fair amount less than 5gb then it may have not reset on your last renewal. Otherwise as noted by @cellphoneuser1  you have consumed all of your plan data for this 30 day cycle.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
cellphoneuser1
@msashakil wrote:
Hi,
There's more detailed usage history in My Account if you click View My Usage. Nothing on the main page in My Data & Add-Ons means it's used up.
