02-21-2020 08:57 AM - edited 01-05-2022 09:36 AM
02-21-2020 11:51 AM
@Sher65 wrote:Yes it states out of data.... but he didnt use it all. Not even half. Thats what the issue is .
@Sher65 The data counter is pretty accurate. In many occasions the data will be used up by upgrades or other app running in the background. The device has a built-in feature that shows data consumption and how many data was used by each app. You just need to sync the dates with the PM plan start date and you should be able to determine what happened
If you still feel that the data counter was in error then submit a ticket to PM for investigation.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
02-21-2020 11:38 AM
Check data usage in add ons after logging into self serve. Data may have been consumed and an data add on could be bought for use until next renewal date. WIFI can be used until then. This is a common issue.
02-21-2020 09:18 AM
Well if it's out of data it means something used it up.
Click "view my usage" under change plan to see the times data was used.
You need to check the phone settings. Have all background data turned off. Updates of apps and system via WI-FI ONLY.
Turn off wifi assist if it's an iPhone or wifi+ if it's an android phone. Where it will automatically reconnect to data if wifi signal is week.
02-21-2020 09:13 AM
02-21-2020 09:13 AM
Maybe screenshot your overview page like above, but omit any personal information. If you don't see the data counter, it means that the data has run out.
02-21-2020 09:12 AM
He can send text messages. Hes going to try some different things when he gets done work.
02-21-2020 09:10 AM - edited 02-21-2020 09:13 AM
Is data enabled .? @Sher65 , can your son send mms messages? If it's blank, he's out of data. Check the phones daya usage to see the greatest culprits. Do some data saving techniques, such as downloading only on WiFi, disable apps from using daya in the background. Etc.
02-21-2020 09:09 AM
Where is says data usage its blank.
02-21-2020 09:06 AM
No it's not.
02-21-2020 09:06 AM
02-21-2020 09:03 AM
@Sher65 Is this a new phone and sign up ?
02-21-2020 09:02 AM
It's my sons phone. He changed to the 40$ plan and he never used all of his data and now it's not working.
02-21-2020 09:01 AM
@Sher65 if you have data, contact the moderators directly through private message here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-21-2020 08:59 AM
More details would be helpful. Was data working before? Which plan were you on? Is it possble that you ran out of data? Check your overview page to see whether you see the data tracker in your Add on section. If you don't see the data counter, that means that you ran out of data.
If you do need to get hold of moderator,
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
02-21-2020 08:58 AM
Has it worked in the past?
Have you checked your account if you still have data and it's not all used up?
What kind of phone do you have?
Check the APN settings. They should be like below.
