Data not working
Canadacup67
Switched plans yesterday. Today data is not working. Same phone. Only difference is the plan.
Impossibly to get an agent or online help.
Any ideas?
17 REPLIES 17
Canadacup67
They did the refresh and all is good. Thanks for your help.
Canadacup67
They responded asking for all my personal account info but I’m not able to monitor it minute by minute so now I’m waiting for a response for that.
@Canadacup67 wrote:
Do you know what they did for you?
I’m waiting now for mine.
HI @Canadacup67
they just refresh your account on the system
did you check the Community inbox for agent's reply?
if you have waited long, like over 2 hours, I would open message PM agent again
Canadacup67
HI @ChaoZ
Yeah.. that's the way to go!!
ChaoZ
After talking to cs agent. My data is working now.
ChaoZ
Thanks. Just did it. waiting...
HI @ChaoZ
quite many has problem with data not working last couple days, especially after a plan change.
to submit ticket, dont' use the chatbot, just use messaging here:
ChaoZ
changed plan to 20gb 5G for 34. Data not working now. It is working yesterday.
Tried to submit a ticket and get 404 error. PM service is so bad.
Canadacup67
I believe I have now. How long does it take to hear back?
hi @Canadacup67
but you can submit ticket by messaging them without error
Canadacup67
I haven’t been able to. I continue to get an error message.
I will keep trying. Thanks.
Canadacup67
Thanks. Reset everything this morning still no luck. Haven’t been able to create a ticket or get an agent.
trying again.
hi @Canadacup67
please submit ticket with agent then
Canadacup67
Thanks. Tried all those this morning. Still nothing.
Chalupa_Batman
Hey @Canadacup67
Best advice is to do a reboot. That doesn't work, go into your network settings and reset your networks. Just know this will erase all saved wifi passwords. Then reboot again. This should fix it.
hi @Canadacup67
many had that problem recently after a plan change
Try Reset All Networks first
if same, submit ticket with CS agent and ask them to refresh your account
